I am a physics PhD student from India working in the field of quantum transport, so we generally fabricate nanoscale devices on small wafers and study quantum phenomena essentially with voltages and currents. Most of the time we measure our devices in cryogenic environments at 4 K and all the way down to a few millikelvins.
I got into 3D printing only a few months ago and I recently came across this incredible project when I was looking to build a simple 3D printed translation stage (of which I didn’t expect much in terms of precision or accuracy). There are so many things in my lab for which we would find it really useful to have a precise stage, and more than building a microscope, I am more interested in incorporating the mechanism of the stage to build something similar to a wafer probe station that can be used to check our devices at room temperature before we load them in our cryostats for long measurements. As I understand it from a couple of posts on this forum, the block stage can be used for making a micromanipulator. For a basic probe station, we would need at least 4 probes which can move independently in X, Y and Z. So is it feasible to have 4 such block stages, each holding a probe that can be adjusted independently? What are the possible challenges I would encounter if I were to attempt to do this? Such a probe station would also require a long working distance microscope with relatively lower magnification, but I guess that can be arranged.
Apart from a probe station, I also would like to build a precise XYZ stage for our samples with at least 20mm translation in XY, but in this case I would also like to know exactly how much (in microns) I am moving my sample in any given direction since this information is needed for an experiment I am working on. Right now, I am using a manual XYZ translation stage with micrometers that has a least count of 10 microns. If I could potentially get even better accuracy with an OFM based stage on top of being motorized, and without breaking the bank on commercially available stages, I would be so happy. While our lab has expensive cryogenic equipment and fab facilities to do our experiments, we just don’t have the funds to invest on these other things unfortunately. As it is, I am thinking of building an OFM microscope just to get a feel for how it works and in what other ways I can incorporate it into my research. We do need more microscopes in our lab as the one and only Olympus microscope does get crowded sometimes. But our devices are opaque (mostly silicon based) and so only reflection based microscopy will work and it also needs to be upright. Any suggestions on what would be the best OFM configuration to build for this?
Apologies for the long post and if I have asked too many questions. I’m just really curious to try this out ![]()
