Using arduino uno
Can Uno be used instead of Nano, with the same sketch, as I have both the standard and delta stage printed, and having a spare Uno.
UNO should be fine. You just need to connect to the correct D pins.
Thanks.
If this does work (which it should) let us know and we can put it in the docs.
Yes its working fine. :+1: :+1: :+1:
