Hi guys!
I’m trying to wire up the motors with the arduino. The fitzing diagram says the xyz motors are connected with xyz actuators respectively but on the delta stage there doesn’t seem to be invidual actuators for each axis and instead .
Does this mean when wiring up the motors for the delta stage, the order of the motors makes no difference? Or which motor on the delta stage is meant to be wired up as the x motor on the fitzring diagram?
Thank you for the help!!
