Today we are launching the Delta Stage v1!
https://openflexure.org/projects/deltastage/
The Delta stage has been refined and is now a fully functional microscope. Thanks to everyone who has given their feedback on the previous designs.
Improvements include:
Refined body design, requiring less plastic, a shorter print time and leaving more space around the optics module.
The optics module is now specially designed for the Delta Stage, so that the camera is correctly oriented for the stage geometry.
The base now has better ventilation and SD card access hole.
Reflection illumination is now supported and the reflection illumination module is more stable.
Illumination using an LED grid is now available (experimental stage).
The documentation is now complete and has a Bill of Materials.
There are now logos on the main body!
35mm petri dish holder adapter for the stage.
The Delta Stage can now be controlled using the familiar OpenFlexure software (requires server version>2.7).
All the components are compatible with the previous version, so if you just want to change the main body, it’ll work fine with all your other existing components.
Hope you find these improvements useful, as always if you have feedback, you can write an issue or use the forum.
