In relation to the delta stage, it appears that there is not a simple way
to remove the fluorescence cube once it is inserted in the slot.
The only way seems to disassemble the main body.
Is there a simple way to solve the problem?
Regards
Nope. It’s the same with the tube lens. You have to actually cut it out of the printed part, carefully.
