I am working on building the Delta Stage v1.2.2 and the M3 nuts I am using are a very tight fit for the condenser mount. The right one barely went in and the left one won’t no matter how much I push. I think making this gap a tiny bit taller may be helpful.
These are the nuts I am using:
https://www.amazon.com/dp/B01IWUSDYY?psc=1&ref=ppx_yo2ov_dt_b_product_details
- Thread Size: M3/0.12"(D); Product Name: Hex Nut
- Material: Carbon Steel; Weight: 32g
- Package Content: 100(+/-2%)pcs x Hex Nut; Main Color: Black
- Height: 2mm/0.08"; Hex Size: 5mm/0.2"(Hex.Width)
- Grade: 8
It’s also possible there is filament in the way of the hole. I will see if I can push the left nut out and clear it if there is.
Edit: pushing the nut out from the top and scrapping the hole made just enough clearance for the nut to fit on the left. So it may just be that there is too much filament falling down from where I printed it. I am not sure if there’s something different that could be done in the model to address this or different print settings that could be used.
Thanks!
