This category if for when you need help with your microscope, Sangaboard, or other OpenFlexure project. You can also open an issue on GitLab. The forum is probably the best place to start if you are unsure what the problem is and just want to ask a question.
New here so unsure where to start. I am so excited with this project and want to build the microscope for which I need help.
For the printed parts I want to know which tolerance should I use:
Printer tolerance: between 0.2 mm, 0.16 mm or 0.1 mm
And for the infill what percentage. Standard infill percentage 15-20% is appropriate?
If someone can advice on this it will be greatly appreciated.
Thanks
Has anyone had success printing the microscope using a stereolithography (SLA) printer, such as the Form 2? I’ve tried printing the main body on my Form 2 without success.
