My goal is to get captured images on my macbook. I’ve heard I can do this by viewing the openflexure microscope on a browser and connecting through a url. I’m having trouble seeing the openflexure in my browser on the same wifi network. Curl can see it but the browser cannot at 192.168.0.177:5000. Chatgpt 5 is zero help on this. The other idea which I also can’t do is to save the captured files to a usb but that’s not happening either – the storage button in the interface doesn’t recognize the usb even though it’s mounted on the desktop. ChatGPT is also not able to find a solution for this either. So I’m stuck.
Hi @techdog , I am a mac user too
Are you mac and the OFM on the same network? 192.168.0.177 - is this the IP address you get with you ping you OFM in the terminal? The IP can change if you connect from a different network, so I just always ping my OFM first.
I experienced the USB issue as well. I used to just scp them via terminal but now with v3 server it can become easier to download the images though - both stitched and individual - so I stopped doing the terminal command bit.
Yes IP address of OFM and mac are the same network. curl can ping the microscope from the mac but the browser cannot open it. I’m on a m1 macbook. I’m trying to avoid having to take out the sd card each time I want to transfer images.
Hi @techdog, I had the same problem on a Mac mini M2 and had two issues:
Control Center is on port 5000. You can check it in your terminal with
sudo lsof -i :5000. If it starts withControlCe, you can turn AirPlay Receiver off in System Settings > General > AirDrop & Handoff > AirPlay Receiver, and toggle it off. -
I also turned on some permissions for my browsers: System Settings > Privacy & Security > Local Network > look for your browsers and toggle them on.
After closing the browsers and restarting the computer, it worked for me.
