Today we are releasing Delta Stage v1.1.0!
https://openflexure.org/projects/deltastage
This upgrade includes better stability between the main body and the base and the base now supports Sangaboard v0.3.
This upgrade is fully compatible with v1.0, so you are able to use your existing main body in the new base.
Hope you find these improvements useful. As always if you have feedback, you can write an issue or use the forum.
