Hello to all makers!
I’m from France and I have started this project at the bigining of december.
And now I have almost all parts!
I’m always waiting from my leds and resistor to finish this nice project…
Regards
Regards
Beau travail !
I’m french speaker from Begium, I’m printing the parts to make one too. May be can you give me some tips to find all material in France and Belgium? Thanks
I’m also active on FB (ATG start)
Hello!
Je peux t’aider si tu veux
(I can help U if you want ;))
Justement je suis français mais je travaille en Belgique.
(I am French, but I work in Belgium)
Super merci beaucoup
Si tu as une liste de fournisseur en Belgique pour la visserie ou le matos électronique ça m’intéresse
(ou ce que tu as déjà utilisé, j’ai peur de me tromper de références). J’aimerais faire le high resolution, le but serait de voir des bactéries : )
j’ai mis pas mal d’infos sur les choses qui fonctionnent pour moi(Sourcing non-printed parts)
@hiphouser : Nice build. The image on screen is rather green. There should be no colour cast at all after you have done the camera calibration. Sometimes calibration does not work properly, and green is a fairly common failure mode. Try running calibrate again (with the slide removed). That will often work, if not try a third time. If that does not work you will need to delete the current lens shading table and start again. I can’t remember exactly where it is, and my microscope is currently off. It is not an option in the interface, you need to delete the file. When it has worked properly you will have a flat neutral grey background.
Ok, thank for U rely.
I’ll try that for better calibration.
But for now, led missing (in transit from China), and it’s just my room light, not the better way.
About that, is it possible to use the raspberry 3.3v gpio pin for use Led light in place of 5v gpio pin and resistor (to reduce to 3.2v)?
I have in idea to try that way…
Am I wrong?
The resistor does more than just reduce the potential difference across the diode to a particular value. It is mainly there to make the current stable when the properties of the LED change a little. An LED is a diode, once the potential difference is high enough for it to switch on the current increases very rapidly for a slightly higher voltage. Not all LEDs are identical, even in the same part number, and the switch-on voltage varies with temperature. Without a resistor these small variations give huge changes in the current. The real issue is that if the current goes too high you may kill your Pi.
Oh! I’ll use the 5v gpio pin and a resistor!
What kind of resistor are you use with theses leds:
It is not really critical unless you want maximum brightness and maximum lifetime. 100 or 60 Ohm are typical. Yours is a relatively low current LED, so needs the higher resistance.
To calculate the best value:
Supply is 5V
The diode forward voltage is 3-3.2V (this is the variability in my last post). Assume 3V here for safety.
The LED maximum current is 20mA.
So when the LED is running there needs to be a potential difference of 5 - 3 = 2V across the resistor. As you say U=I R, so R = 2/0.02 = 100 Ohm
It does not need to be an exact calculation. If the current is lower you get less light, but the Pi camera is very sensitive so that would be OK. LEDs are tolerant of some over current, but not a huge amount, so best to err on the low side. The Pi will easily cope with that current.
OK. Tank again!
I am also building the microscope in Belgium/ Brussels (french speaking) and I’d love to have your advice/build it together
@atgstart : Je me lance aussi dans la construction du microscope à Bruxelles.
Je serais super chaud discuter ensemble un jour pour collaborer.
Fantastic to see the project getting more international! Very happy to set up a French language category on the forum is this would be helpful. Of course converse here in what ever language you want
We are updating the documentation to simplify it. It would be fantastic to get non-native speakers to give feedback on how easy it is to follow. We also need to think about the best way to manage translations if anyone has ideas.
@JPBiomed: I can help you if you want
Je peux t’aider si tu as besoin
@j.stirling: Yes it’s a very nice project!
Thank to all community form your help!
I am also based in Brussels.(French native, also present near Dijon regularly)
I am almost finished building my openflexure and I am working on finding the optimal configuration for human sperm analysis (focus is on establishing concentration only at first).
The aim is to simplify and make more accessible male contraception follow up at home (which of course can never replace a true medical lab verdict)
In case you are interested and have some biology background, suggestions will be welcome !
Best
Hi Rupert,
I have not yet finished my OpenFlexure Microscope but it would be a pleasure to collaborate on it
You can contact me on my facebook page or on my email adress :
Cordialement
Hi Rupert,
I l currently investigating th feasibility to make it a medical device for Africa (I’m in East Africa for the next 3 months) but also had in mind the fertility assessment for BE and the EU in general.
My father wants to start using it in his school so it might be a good idea to connect with him
Regarding the clinical applications for BE, a guy I know is using it for hematology in Bruges. I can get you I touch.
Best
