Have you run an OFM workshop? Share your experience
Hi all,
There have been so many cool workshops using the OFM, in many different parts of the world… I was wondering if you’d like to share how you design and implement them, so we can all learn?
If you have conducted a workshop in any setting in the past (or if you’re planning one), it would be great to know:
  • Audience of your workshop?
  • Workflow: which activities have you planned, which “exercises”?
  • Materials: which OFM versions do you use? Which samples?
  • Schedule: how long did it take?
  • How many people were facilitating?
  • Any other useful info
Maybe we can put up a guide and help others run workshops?
I’ve actually not run one myself for ages (years), so most of my experience is quite out of date. However, it’s worth mentioning a few things I’ve picked up:
  • I reckon on about and hour to build a microscope if you have all the bits and know what you’re doing. Allowing 2-3 hours is much safer, and leaves some time to play with it at the end.
  • I’ve previously tried to print out the instructions as a PDF. I am not sure that works so well with the current GitBuilding ones; you’d want to make sure each group had a laptop/tablet to view them.
  • Once you’ve built some microscopes, there’s very little on the OpenFlexure site about what to do with them. I’d really love to expand that, and/or link to some resources elsewhere.
  • Usually 2-3 people running a workshop for 10-20 people works quite well. @JohemianKnapsody has had to run demos with far bigger participant-presenter ratios, I suspect he would confirm this is quite tricky!
  • I’ve done this with secondary school pupils, and with PhD students/postdocs. The latter were much more highly skilled, but much less good at following the instructions! That meant they completed in roughly the same length of time…
  • I’ve not done this since v6.1.5. The most fun workshop was definitely where we built motorised ones, and I tried to get the participants to code their own autofocus routine.
I finished a workshop last week. It was quite straight forward thanks to existing official OpenFlexure build instructions.
    8 Gymnasium teachers (teaching age 15 - 19)
    First a short intro (1 h), then bulding a microscope (max 5 h) and the remaining time looking at fresh and marine water samples.
    Low-cost version. Fresh and marine water samples.
    3-5 h for the building and ~1h for calibration and going through Openflexure connect/browser. Remaining ~1 h to look at samples.
    Two. Me + engineer from the collaborating science center.
    Test cameras prior.
I ran a similar workshop again (2025-06-17) that gave some useful info:
  • Avoid “work”-computers. A couple participating teachers brought computers from work. Work computers tend to have security specifications making it difficult to connect to devices such as the microscope. I don’t know what exact security issues, and if their is an easy fix, but I try to recommend all participates to bring their private laptops for testing their built microscope.
For some reason many Windows computers refuse to open the OpenFlexure Connect install file if it is downloaded. The work-around is to have the download on a USB drive, even locked down work computers have been happy to run that.
One can also run the microscope from inside any browser. OpenFlexure Connect is only really necessary if you want to attach more than one microscope to the same computer - then you need to know what names/addresses they have sorted out for each one.
There might be additional problems connecting to a peer-to-peer network suing a USB-LAN adapter. There are probably system settings available that can lock that out, more commonly I have found that some USB-LAN adapters just don’t work with some computers.
Thanks for the info! We installed OF Connect but the microscopes were not detected, nor were they accessible from inside the browser. The bothersome computers were municipal computers, so I thought it might have to do with them not allowing certain information over ethernet connections.
That can be hard to work out. Was it a wired connection with USB-ethernet adapter, or everything on a WiFi network? Either can cause problems with managed network settings, or with particular USB adapters.
It was all wired, both with different USB-ethernet adapters as well as some with direct ethernet connection. Maybe it could have worked over WiFi, assuming they can find and connect to the network. Then I need to have a WiFi accessible during the workshop as well as prepare each SD-img with those WiFi logins. That would be worth it as an extra last resort/backup solution. Thanks!
