I have a sample with significant topography that I am scanning using the OFM software. I have been trying to modify the autofocus extension to be better at autofocussing on such a sample but I am having trouble. As I understand, in the standard autofocus initially the focus moves up (or down?) a certain amount then the z axis is moved in increments of 10/30/100 steps depending whether coarse/medium/fine is chosen. I am trying to find a way to modify the amount of steps the initial movement is & subsequently how many steps (as in increments) the autofocus performs back down before deciding which image is sharpest. I have looked at the extension code but can’t figure out how to alter these parameters. Any help would be appreciated!
Hi @Ryan the step size and range are set when you call the autofocus method; if you’re using the web interface, the parameters are baked in to the code that calls “coarse/medium/fine”. Currently the only way to customise what happens when you click the button would be to modify the web app, but it’s easier to customise if you are using e.g the python client. How would you like to do it?
If you direct me to the section of code that determines the step size and range in the web app I should be able to play around with the parameters. I think having it baked into the code is easier as I perform numerous scans per day.
Sure - I am guessing you want to change the autofocus parameters used in the scan, rather than just when you click the autofocus buttons? If so, the relevant file is openflexure_microscope/api/static/src/components/tabContentComponents/captureComponents/paneCapture.vue line 379, that defines the step size for autofocus. Note that “fast” autofocus is a special case, it defines the total range instead, as it doesn’t move in discrete steps.
If you want to play with the parameters without having to modify the web app every time, open a web browser and enter your microscope’s address with port 5000 and /api/v2/docs/swagger-ui, i.e.
Richard and Ryan,
I have attempted to do the same thing to improve the autofocus when scanning at larger intervals using a 10x lens. I was able to test the optimal range for the autofocus using the web browser interface and found where to modify the paneCapture.vue file.
I have read the ReadMe file but I am having trouble understanding how to compile and run the microscope web app.
To rebuild the webapp after making some changes, the instructions are here
The key points are that you need npm and nodejs installed, then rebuild the app. I normally do this on the Raspberry Pi (since that’s where the webapp actually runs), but you can also do it on your computer and then copy the files across
Any questions, let me know, this is documentation we should be making really clear!
Joe
This is so awesome that one can play with the parameters here! On the low res OFM I can typically take steps of 5000 and still get good overlap for stitching, but I wish I could extend the autofocus range from the default 2000 to 4000 as sometimes I get whole areas blurry… Do I need to rebuild the app to make the new parameter value “stick” for one scanning session?
You may need to rebuild it to make it persistent - it’s worth saying that our development effort is now all focused on v3, so I’m less and less familiar with the v2 codebase. Scanning is much, much improved in the newer version - though it’s also more tightly optimised so it doesn’t (yet) have as many options as v2.
Sure, there’s an alpha release, I think there’s a thread in “announcements”. As with most alpha releases, there are a few issues we’ve fixed and they’ll be in the next alpha…
I am accessing the code on my Raspberry Pi via WinSCP. Is there somewhere I could change the autofocus range that would remain persistent? I typically run the OFM using Openflexure Connect, but I am scanning large areas with large steps, and the focus between the center and edges of my scans is often 8000 steps apart.
Currently I think the number is hard coded in the web application, at least if you’re running V2 software. You would need to change it in the Vue source code and then rebuild the web app (which you can do over SSH but you’d need a terminal, not just scp).
This is something we should improve in V3, I’m ashamed to say I can’t remember if that’s happened already on the development branch but we’ve certainly talked about it.
I will make sure to watch for any notes about it in further releases. For now it’s something I can deal with in my images, but it would definitely improve the quality of life for the process.
