I have been working on the design for a filament tester:
This is entirely 3D printed (requiring no other parts), and consists of a frame in which a sample is placed for testing.
Two tests are supported:
In both cases the strength of the sample can be recorded, either by measuring the amount of rotation of the test tool, or of the force exerted at the moment of failure.
Tester design
The tester consists of a frame. The frame is embedded in a base plate with holes at 25mm centres to allow for easy fixing to a bench (though basic testing can be done simply holding it in your hand)
The frame is printed in two parts, with the top part connected using dovetails to the walls of the frame. (This is a friction fit, there’s no need to glue it in)
The top of the frame contains a threaded hole, into which the tester tool is inserted. Rotating this changes the height of a connection nub. This nub mates with the sample, and depending on the sample shape, either twists the sample, or pulls it upwards.
To assist with measuring the rotation or forces involved, gradations are marked on the top of the frame at 10 degree intervals. The arm of the tool has a hole at 100mm from the centre of rotation in which a cord to a load cell etc could be attached.
Testing method
- Insert the tester tool downwards into the frame
- Insert sample into the frame ensuring it is fully under the centre, and mated with the nub of the tool.
- Rotate tool to raise it, until the sample fails.
- Note the angle of rotation of the tool, or the force applied to the tool at the moment of failure.
Repeat several times and average the results.
Notes on 3D printing the tool and samples
This is designed to be printed without the need for supports.
Attached are the individual STEP files.
The forum won’t let me upload a 3MF file here, so I have uploaded to MakerWorld:
3MF model on MakerWorld
The general settings I used are 2 walls, 25% gyroid infill (except for the threaded end of the tool where a modifier has been used to make it solid with 99 walls). A thin layer height of 0.08 is desirable for the threaded parts (the tool and the top of the frame) otherwise the threads will feel a bit lumpy as you rotate them, which interferes with measurements. For the rest, a standard layer height of 0.2 is fine.
I have successfully printed this in PLA on a Bambu P1S.
Samples appear to gain some strength as they cool after printing, so best not to test them immediately after printing them.
Files
Frame and tool:
FTesterFrameBody.step (62.9 KB)
FTesterFrameTop.step (2.2 MB)
FTesterBolt.step (219.2 KB)
Test pieces:
FTester-PiecePull2.step (47.5 KB)
FTester-PieceTwist2.step (42.3 KB)
