OpenFlexure Connect version 5.0.0!
It has been way too long since OpenFlexure Connect got a new release. We hare happy to say it is online!
Hopefully you will not notice much of a difference except a few more things working if you are using the v3 server pre-releases. We recommend installing it as it is far more up-to-date and secure.
Installing
You can get the new version a number of ways:
  • From an old version of Connect, via the Help menu
Notes for other platforms:
  • We don’t yet publish for MacOS. It should build on MacOS, but we don’t have anyone on the team with a mac for testing. I believe we may also have to buy a Mac developer license to try it or publish it. If anyone has experience building for MacOS we would love some help.
  • Snaps are now only published for x86-64 not for 32-bit Arm. We may add 64-bit arm in the future. Let us know if you are a snap user on an unsupported architecture.
  • We are no longer publishing on Choco. If you are a windows user who uses choco or another command line install package let us know and we will see what we can do
Release notes
  • Native support for the v3 API of the Microscope and the v3 fallback server
  • A custom about modal
  • Fixed size image previews, preventing square streams overlapping other content.
Developer changes
  • Vendor our own updated copy of mdns-js and dependencies.
  • Update from Electron v9 to Electron v36!
  • Update from Vue2 to Vue3
  • Re-scaffold the project with a newer dev toolchain and electron-vite
I am getting an error when I try to start openflexure-connect 5.0 on Ubuntu systems:
Line 2: /snap/openflexure-connect/9/desktop-init.sh: no such file or directory
Ken
I am not sure that I can help, but there are a couple of details which might clarify the nature of the issue. The error mentions snap, did you install through the Snap store? Is this a fresh install, or by upgrading an existing v4 installation of OpenFlexure Connect from within Connect?
Hi Ken,
Did you directly download the snap, or install it from snapcraft (using snap install). If you want to download it directly I’d use the appimage.
On one machine I did an upgrade from the app, then I uninstalled and reinstalled using snap. When that gave me the same error I installed, also with snap, on another computer that never had the program and got the same error about a missing script. Also I could not find the script when I looked for it.
When you say you did the upgrade from the app, this was also previously a snap, or was the appImage? I am using the app image in Kubuntu, I should test the snap
I’m pretty sure it a snap that I tried to upgrade.
OK, Sorry. I can reproduce this bug.
It seems that electron-builder updated just before release when we were updating our lock file and it introduced a change that broke snaps.
Other applications have seen similar issues. The issue in electron-builder was fixed 4 days ago. But there has not been a release since.
I am currently travelling, so it may be early August before I get to this so I think the plan is:
  • If a new release is out in early August with a fix we make v5.0.1 with that.
  • If not we downgrade our electron-builder for v5.0.1
How do I use the app image? And would installing the missing file fix the problem?
Ken
Normally downloading the app image, make it executable (from a terminal in the directory of the downloaded file):
chmod +x openflexure-connect-5.0.0-x86_64.AppImage
then run it with:
./openflexure-connect-5.0.0-x86_64.AppImage
Depending on the Ubuntu version they have some weird sandboxing issue, so you may need to run
./openflexure-connect-5.0.0-x86_64.AppImage --no-sandbox
I don’t think so as snaps run in a virtualised file system for the snap. As far a I understand we would need the image to be in this virtual system, and the bug in electron-builder is that it didn’t bundle it to be unpacked into this virtual system.
