Microscope case solutions for field kit and travelling
Hi there,
I am foremost posting this out of curiosity to know what case/box solutions others are using when working with their microscopes, e.g in the field or for travelling. Inspired by A compact travel kit-post I use an off-brand IP65 41x31x18cm hard case (image below) with room made for battery, wifi module, charger and toolkit.
On the topic, so far I have found these interesting posts related to OFM boxing/casing:
A compact travel kit (2025)
Dust cover (2025)
Laser cut for storage/carrying (2025)
Boxed variant (2024)
Protective cover (2024)
Transport case (2021)
I would love to hear about your case solution, or if you know some relevant forum post to add to the list.
I also want to use the opportunity to present an initiative to develop a printable hard case, initiated by @Patrice PSL3D (https://www.psl3d.fr/) (image below).
The aim is to develop a printable robust field kit hard case for the OFM v7. This thread will be updated throughout the development process, with stl’s made available. Anyone interested in sharing their thoughts, ideas, suggestions are welcome to join.
Best regards
Per and @Patrice
I wanted to make my contribution to this project. I made this stackable box to hold the electronics and a 2.5mm Hex Key.
Hex Key
https://makerworld.com/en/models/1880620-hex-key-for-ofm-2-5mm#profileId-2013671
Box:
https://makerworld.com/en/models/1880710-openflexure-microscope-tool-box#profileId-2013757
I love the toolbox @dgrosen!
The hex key looks like it is useful in a bind if an allen key is unavailable, but I would worry that it will break if used too much. The would be really hard to access if it broke in the z-actuator. Out of interest have you tried it in the z-actuator? I would have assumed it needed a ball nose to get into the hex socket.
Would you be able to put the stls or design files here? It is not so easy to extract them from makerworld for other printers.
Still a work in progress but this is where we’re heading…
Thank Patrice, this looks very cool. I really like that when the lid comes off the microscope is ready to run.
These feel more like a storage box than a travel/field kit as there is minimal protection for the microscope? If the outer case is directly coupled to the microscope via the wedges that hold the motor then any vibration or knock on the case will couple directly into the microscope risking damaging the flexure (especially the z-flexure). As compared to Per’s case above where the microscope is surrounded by foam to damp vibrations during travel.
The idea is to have TPU bumpers (bottom and motors as you guessed) holding the microscope in place within the PETG casing so indeed it can travel. We’ve been using this concept on various items with success. Of course, its needs testing and refining.
Interesting. Yes, I suppose it depends on how soft those bumpers are. I suppose you can tune that with infill?
One thing we have been thinking about is if we need a second mount for the Objective so that we take the objective out of the keyhole on the actuator, rotate it, and connect it to a second stationary mount on the wall during transport.
It does mean getting set up is harder, but also will protect the mechanism.
We’ve also included a humidity sensor as you can see : we make things for research in tropical climates and it has proven a good idea so far. The idea is obviously to wait until inside temp ~= outside so humidity doesn’t precipitate on the electronics and optics when you open the lid. Also, you can open, place your sample, close and then use the microscope from outside the box in order to maximise security.
Yep : we tend to prefer gyroid, no walls and try various % of infill.
We’re thinking about a slightly bigger version that could incorporate more stuff like minimal tool kit, battery pack… in a small form factor, easy to just open and work in precarious conditions.
thanks @dgrosen
that stackable box looks really nice, I will definitely try to print those.
That does not seem to work properly if you are not logged in.
I’m not logged in. I hate this bambu thing as it sucks everything it can datawise. Maybe a browser issue.
It works with chrome and brave my end.
Here are a few images of V1 of PSL3D’s hard case for the OFM.
The case is very rigid and the microscope stand fits perfect into the bottom frame.
The height of case limits how high the illumination (condenser arm) can be mounted.
Regarding the locking mechanism:
When closing and opening the case using the locking mechanism (green), the smaller green wedges sometimes get stuck positioned against the case (right side, bottom half of image). This results in the the locking mechanism not working properly and thus the top part of the case not being properly attached.
We’ll update this post with changes made to case height and locking mechanism.
Best regards
Per
Adding a cross link to A mini microscope case that works for me
