How to use the nano converter plate and gripper? - Sangaboard alternative
I’m using the Sangaboard workaround using the Arduino Nano alternative. I printed the nano_converter_plate-pi4.stl and nano_converter_plate_gripper.stl, but I’m not sure how to use them to assemble/organize my components. Has anyone already used? I would appreciate it if anyone can share the pictures or documentation about it.
@anpaternina I am sorry that the instructions are still incomplete for the nano electronics workaround. There are a couple of posts where it is discussed:
Custom ofm for project - #10 by WilliamW - which is my explanation as far back as May 2024 :frowning:
First build - High Resolution OFM - #2 by mzedp has a good photo of the boards installed, but you cannot see the clip as it is at the back end of the nano.
Hi @anpaternina , I have this photos of my own assembly process. I hope this helps :slight_smile:
Thank you so much for share the usefull links and pictures @WilliamW @Paola_Larrauri. Perhaps we can add those pictures to the oficial documentation.
Yes! In fact, I still need to share my own documentation, experience, and applications of OFM in my doctoral thesis :slight_smile:
