Delta stage build parallax effect question
I am planning to print a Delta stage this week. I have a question regarding the motorized control.
I understand the optics are fixed and the whole stage moves up and down for focusing. Is the the software for Delta Stage different? I am thinking that if the software only moves the Z axis motor there will be parallax effect. Does the software move all 3 axis to compensate the parallax effect?
Thanks
Hello!
The delta stage uses the same software as the standard microscope. As of v2.8 the software has an option to change stage configuration to the Delta stage. The instructions to do this can be found on the Use the Delta Stage page.
Thanks
Thanks! just saw it in the setting option. You guys are AWESOME!
