Adaption of PUMA SLM for openflexure scope
I am interested in the PUMA spatial light modulator. I think the openflexure is a better choice than PUMA in general but their spatial light modulator seems an elegant approach to filtering.
I had not seen that SLM. It is a bit delicate to prepare, but would be very useful. As the PUMA adds the SLM into a Kohler illumination system it is separate from the translation and imaging optics systems. I think it should be possible to mount the PUMA illumination onto an Openflexure Microscope or Deltastage body. It is a rather larger part than the standard Openflexure illumination and may be too wide to attach to illumination dovetail, but that is not a show stopper.
I could not immediately see where the STLs for the PUMA illumination are to check on the actual sizes.
Trying out the PUMA illumination would be fun - if I remember correctly, the illumination SLM is effectively doing a similar thing to the LED array that Samuel set up on the delta stage (which should also work on the inverted microscope).
https://opg.optica.org/oe/fulltext.cfm?uri=oe-30-15-26377&id=477856
However, the PUMA version should suffer less from stray light and may have a few other advantages, so it could be quite fun.
I suspect the one for the delta stage would be easier to implement. The PUMA one is pretty complex. Didn’t know about the one you described, when I start up my microscope work- will give it a try.
Thanks!
