Z Actuator Insertion O-Ring Issue
Hi, is there any tip how to assamble the O-Ring on Z Actuator. For X and Y Actuator it was no Problem,
but i cant get it for thr Z Actuator running. There are two clicks, one for each side but when i try to pull out the insertion tool it looses the grip. What can i try else
lg Sers
The three actuators are basically the same. As you are getting x and y to work then you seem to have the right method. Maybe something did not quite print correctly in the z-axis?
Hi, i printed the main-body with a better resolution and so it works for the first time
thank u
