Was having a bit of an extrusion issue in the first layer, so it isn’t beautiful. I was wondering if I use the smooth bed if I can paint fill the letters like you would for a brass plaque.
The text is a bit funky with a textured bed (or on mine with a flat bed). Perhaps I should remove it?
I think that the clasp is much easier to operate the correct way up so we probably don’t need to worry too much about the text. Perhaps we need to just make it easier to buy OpenFlexure stickers. Then we can put a sticker on the top!
Hi @ebob,
I also printed with 0.4 mm nozzle, without ironing.
For the text, I think bottom warning is a nice touch. I can’t remember how many times I opened a slide holder wrong and created a mess (100 slides everywhere ).
As @ebob says, it is parametric. Much smaller than 15 it may have problems catching on the front slide and the clearance parameter may need increasing.
Otherwise it should be type in a number and go.
Here is 16 and 24. I’ve not tested them but they should work
Here’s the 24 slide version, printed in Sunlu’s Transparent PLA.
The reality of 3D printing means it’s more ‘translucent’ than transparent, even when printed with a smooth plate, ironing on, and 100% infill. However, you can still see through the wall that there are a couple of slides in it, which is fun.
