Sangaboard problem
Hello everyone, I need your help. My Sangaboard suddenly can’t connect to the Raspberry Pi, and it keeps showing the error: "ERROR: 'MissingStage' object has no attribute 'board'". What should I do to troubleshoot this issue?
It showed words here before.
Have you made any modifications to your microscope before this happened? Could it be a poor connection because something moved or a software change?
The first troubleshooting would be to try some direct serial communication to the Sangaboard. That would tell you whether the Sangaboard is working and the problem is the microscope software, or that the Sangaboard is not working for some reason.
