There is a thread here on modifications for the new Pi High Quality camera. There is not yet a good solution for filling the bigger sensor of the new camera, while keeping the module compact. If you leave the tube lens as it is for the RPi V2 camera, then you will need to be careful with planning the camera mount to put the new image sensor in exactly the same place as the old one. That should give a focused image, but it will not fill the sensor area.
