Hi all,
I’m pushing out a new beta release of the OpenFlexure Microscope Server today.
If you want to help test, please run
sudo ofm update
sudo ofm upgrade --pre
from your microscope shell.
Changelog
JS Client changes
- By making proper use of the capture resource changes (below), memory consumption has been drastically reduced.
Capture resource changes
metadatakey removed from capture array elements -
acquisitionDaterenamed totimein Capture resource top-level -
datasetkey added to top-level of Capture resources
The usual beta release disclaimers apply here! This version has not been extensively tested, so while it seems to work fine to me, bugs will happen. Do not use this for anything mission-critical.
Thanks!
