I want to make an extension for the v3 version of the software, so I don’t have to rewrite it later. Is there a development guide to run the v3 server or is it too early in development to run?
The server v3 is not at an alpha release yet, and there is also not yet a development guide for you to compile it yourself. @r.w.bowman might be able to help with a current compiled image, but i don’t know whether that would enable you to develop an extension.
The tool to customise the image is here:
If you can run that (needs linux, qemu-arm-static, and a few other disk image related utilities - I mostly use Ubuntu 24 in WSL2, i.e. on my Windows laptop), it will download a stock Bookworm image and install everything that’s required on it.
“Extensions” for v3 are simply “Things” as defined by labthings_fastapi, which is about the one thing I have made a start on documentation for:
https://labthings-fastapi.readthedocs.io/en/latest/
I do now have a server purchased, and once I’ve found time to set it up I’ll be able to share a pre-release image. I think v3 currently works about as well as v2, but may be slightly more faff to set up, and is missing a few features. I should probably “get it out there” as a nearly-complete alpha, because that will help focus effort on the most important features to re-implement from v2.
@Nico Once you’ve got a working version of v3 pre-alpha installed, I’m happy to give you some pointers on making a Thing if that’d be helpful. I’d say it’s easier than adding them for v2
will v2 extensions still work on v3?
No, v3 is a breaking change.
