Buying Beamsplitter for reflection illumination
Hi, i m from Austria and ask for some links where i can buy such a Splitter 50/50 with 45 degrees. All the other equipment i found on AliExp.
thanks
I live in the uk and I have bought all of my plate beam splitters from knight optical; I believe they also deliver to EU. I’ve also ordered some beamsplitters from aliexpress. Are you having trouble finding them? If so I can send you a link or two.
Ryan
Hi Ryan thanks for your support. I couldn’t find on aliexp so links also for knight optical would be great
Knight optical: https://www.knightoptical.com/stock/default/plate-beamsplitter-standard-range-50-50-visible-450-700nm-15x10x1mmthk.html
Aliexpress: https://www.aliexpress.com/item/4000712197543.html?spm=a2g0o.productlist.0.0.7e093736x8nsuc&algo_pvid=e4a676fc-ac34-4142-9ea0-ac11d3ef8697&algo_expid=e4a676fc-ac34-4142-9ea0-ac11d3ef8697-12&btsid=0bb0623f16039199696568790eef9a&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
I can’t remeber the exact size that the plate is supposed to be but I hope these help.
Ryan
That helps a lot. Thanks for your helping hand
:+1:
