I need to meditate a bit over this. 5 degrees of freedom is quite a lot for this small of a space. Especially if you want at leasr some of them to be independently adjustable.
That is a fair point. yeah, we would need pretty reliably specāed lenses to actually programmatically set things
Drawings are great for reimplementation, so is source CAD. It seems I can access OnShape on Linux? I have never tried, but yes source would be useful too, my understanding is that source CAD canāt be downlowded in OnShape but in theory it should be perpetual?
@j.stirling OnShape is browser based so it should port well to linux. The only issues you may have is with the hardware acceleration that may or may not be needed to render in browser.
Here are links to the public document. I created both condensers within the same document but saved them as different versions. There is virtually no parameterization of the objects in this document; save for the light stop used in the darkfield condenser. Itās a prototype doc so itās a mess.
Darkfield condenser
Note that the kohler condenser does not include the apertures - I used the ones from this thingiverse link. The gaps are included - the apertures are about 8mm thick.
No worries about hardware acceleration every computer I own is getting on for 10 years old and doesnāt have much hardware to accelerate anything anyway! Iāll have a play later in the week
2+1 degrees of freedom is all we need surely? At >0.5NA small angular misalignment is not really relevant.
However the xy position adjustment could be done by angle adjustment instead if that were easier.
My take would be to use the existing separate z-axis from the Upright (would need to move back to give space for the larger condenser, but that could be done in the spacer). Then xy adjustment on an aperture in Kohler, or on the LED itself in non-Kohler. I think the xy position of the lenses will be OK within print accuracy.
I need to do a bit of testing to see how well aligned things are.
