Hello, I am new to open flexure. Interested in using a TensorFlow-Lite object detection model to count microbes. I recently developed a demo model for counting spirochete bacteria (https://spirocount.github.io/). Currently building an OFM and hoping to get dark field microscopy good enough to continue. After that, looking to build an easy to use (touch screen?) interface to display and control automated counting. I am still exploring options and I am happy this exists! Also, would be happy to collaborate!
great, welcome! Do stay in touch - dark field ought to be OK at least for low NA (e.g. 40x, 0.65NA and @samuelmcdermott has got this working with the LED array on the delta stage (it should work just the same for the regular microscope too).
I am interested too, Not sure what i can do to help out here.
Interested and curious to what has already been done? Most interested in sticking open flexure 7.0 into an incubator with a cell culture flask or Petri dish and monitor the culture automatically using computer vision.
I know there are a few folk who have done this (microscopes in incubators), though I’m not sure to what extent their workflow uses automated image analysis. I’d have thought the analysis may be quite standard, though, and it would be lovely to see some links between here and image.sc if you find anything relevant there. This reminds me of some of the work @quigly has done, so I’ll tag him here just in case there’s a useful connection.
Yeah for the past few years I’ve had some scopes in my incubator to make movies of macrophages infected with yeast in 35 mm petri dishes, I have it take an image once every minute for 24 hours. I can fit four scopes easily in one incubator and could probably even get four more on a second shelf if I really tried. Overall it works incredibly well, the main thing to be careful of is that the PLA will become brittle so just be careful if you have to manually adjust any of the pieces. I’ve wanted to try making one out of other materials like ABS but still haven’t gotten around to it.
To remote desktop I just use VNC and set up a hotspot on my desktop in the next room. The IT department has set up some restriction making it so the pi’s can’t connect to the wifi so if you run into an issue like that hotspotting works great, my hotspot is in another room across the hall from the incubator and the signal is still great. Controlling the motorized stages worked fine (I used the arduino nano rather than the sangaboard version) and ideally I’ll to move up to scanning fields of view but right now I pretty much just do one static field of view and don’t have to change focus much, if at all, between plates.
I haven’t gotten very far with automating analysis though as I’m trying to track these small yeasts as they travel between macrophages and being able to segment and track all these fast moving, changing, and overlapping macrophages has been rough. Depending on what you’re doing it might be very easy, like if you’re just looking to monitor for confluence or something I think that would work well off the bat.
Hello, Quigly: This is a pretty good use for the OFM, in my opinion. I am a pathologist with experience with tissue culture techniques and thought to give it a shot as well. Of course, this will need some Python code which I am not really good at. In any case, I wanted to share a couple of my thoughts with you.
I would print the scopes with high-temperature PLA that can withstand temperatures of up to 80 degrees Celsius. ABS may be overly stiff and interfere with the OFM’s restricted range of motion.
Tissue cultures are useful because cells grow on a monolayer and you don’t have to focus too hard. If you have any organoid structures or cell groupings, you may “z-stack” the photos. This can be accomplished using ImageJ (fiji).
Any recent updates on this ?
I’m looking into adapting the OFM for Raman microscopy (e.g bacterial detection). I am also very interested in AI-related diagnostics in general.
Would be very happy to collaborate on any ongoing projects !
I am not sure what the current AI/ML status is, but we are making steady progress towards releasing a stable version 7 of the hardware. Version 3 of the software development is also continuing, and there should be a pre-release soon, this new software this new software should allow much more flexibility in which computer hardware the microscope uses. This may make it easier for ML applications, or for further hardware customisation.
As for Raman spectroscopy, I don’t know anyone currently doing OpenFlexure Raman, but it would be awesome to see that working.
There is some work being published.I bet there are some experimenting with other aspects of AI using the OFM.
https://www.thelancet.com/journals/ebiom/article/PIIS2352-3964(24)00312-8/fulltext
I’m interested in the AI/ML side of things, and also in getting OFM used in schools. I’m in the UK.
I note that Raspberry Pi have just released a new camera module with built-in AI compute capability. see the thread on it here:
Hey all, I’m new here. I’m doing much of the same work as what I’ve seen mentioned here. I think regardless of what hardware acceleration you have on the OpenFlexure, you can still deploy a CPU-based model to analyze a slide. It may not run as fast, but it would certainly work all the same.
I’m working on high-resolution segmentation models for my OpenFlexure setup. I am looking to improve the ML tooling, add ML-based automation features, and build datasets and models that can be shared with the community.
Interesting sputs! how is this coming along?
Nice! I am actually working on malaria detection at the moment, would be great if we could link up
Welcome Ditiro,
I was just wondering if you have built an OpenFlexure Microscope yet in Botswana and if so how easy it was to source components.
Thank you Julian,
We are currently printing parts for ourselves, for the electronic parts, we have most of them from our innovation lab. For the camera module, we are finding it difficult to connect it to the OS, we have module 3 instead of 2
The only camera that is supported at present is the Pi Camera v2.
In the new Openflexure Server software, v3 (currently in alpha pre-release on another thread here), the architecture is changed to make it possible to add other cameras. The Pi Camera HQ is going to be the first that gets support. The Pi Camera Module 3 is not on the plan for the short term it does not really offer any improvement over the v2 in the microscope.
