Finished my first build (high res, v7)
More photos here: https://photos.app.goo.gl/cGhSBy9M1yzqSTEq8
Went pretty smoothly, some slightly wonky nut holders took a bit of wiggling. The right hand X axis securing hole came out a bit large so it’s only just holding (works anyway :smile:). I was a bit worried when I saw in the instructions that the 8GB pi 4 was not supported, but as you can see in the photo, it’s working fine.
Amazing project!
Glad you like it. When you say the nuts needed wiggling, was that to get the nut into the slot on things like the lugs in the stand? There is a small modification to the shape of the slots coming in the next update, to reduce stringing and make those better. Is your print from the current v7.0.0-beta3 release?
And the x-axis securing hole is one of the motor screws? I am thinking that it might be better to specify a longer screw there.
A few of the holes had some stringing which make the nut insertion a little bit more difficult, unfortunately I didn’t keep track of which ones. It wasn’t that big a deal.
Yes
Yes, it was the right hand motor screw when viewed from the back. The hole gave a bit as I tightened the screw and so I can no longer make it very tight, but it’s not affecting functionality.
