Yes, the main DIN thread is the RMS thread ~20mm, although there are also larger diameter threads.
The other parameter is the par-focal distance - from the thread to the object. 45mm is common and fits. I think the other common one is 35mm which certainly should fit without the stage riser, and probably fits with the riser.
