I am certainly not up to the task maintaining a distribution, but i’ve done alot of linux client and server management for work, and when doing gitlab-issues in the future, i promise to give helpful advice ragarding on how to do something. However, what i can already say, that approach on how you do it now, so taking the raspbian base-image and then consecutively apply some recipes/scripts that change some things related to a certain topic is definately the way to go. building may sometimes take a little bit longer that way, but you always have fresh, reproducible builds, this is the way how it should be done anyways, even tough i might have choosen ansible for that task, to be able to easily apply changes to an already deployed system in a simple manner. I don’t think that there is very much more sophisticated to do, except building a checklist of things that have to work and how it has to work, regularily build images with updated packages, and check if any of the updates conflicts or interacts with the changes to the base-os you apply afterwards. there is not very much to it. Maybe pay attention to not hardcode things. In the GUI-Version of the current stable build the desktop shortcuts don’t work, because the username in the .desktop-files are sometimes hardcoded to “pi” as username (and therefore the path of the homedir where some apps are located). But other than that, many things are already done very much the right way…
however, back to the v3-release: I just experienced an unhandled crash of the stitching progcess causing the scanning to halt. The running scan was not abortable and restarting the openflexure-server unit did eventually complete, but not leading to the UI be available again unfortunately. I tought you were interested in the dmesg-trail:
[24449.032958] vc_sm_cma_vchi_rx_ack: received response 0, throw away...
[24971.284060] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000008
[24971.284102] Mem abort info:
[24971.284107] ESR = 0x0000000096000047
[24971.284113] EC = 0x25: DABT (current EL), IL = 32 bits
[24971.284120] SET = 0, FnV = 0
[24971.284125] EA = 0, S1PTW = 0
[24971.284129] FSC = 0x07: level 3 translation fault
[24971.284136] Data abort info:
[24971.284140] ISV = 0, ISS = 0x00000047, ISS2 = 0x00000000
[24971.284146] CM = 0, WnR = 1, TnD = 0, TagAccess = 0
[24971.284152] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
[24971.284158] user pgtable: 4k pages, 39-bit VAs, pgdp=0000000080d0c000
[24971.284166] [0000000000000008] pgd=0800000041d06003, p4d=0800000041d06003, pud=0800000041d06003, pmd=0800000084b99003, pte=0000000000000000
[24971.284192] Internal error: Oops: 0000000096000047 [#1] PREEMPT SMP
[24971.284201] Modules linked in: cmac algif_hash aes_arm64 aes_generic algif_skcipher af_alg bnep brcmfmac_wcc imx219 v4l2_cci regmap_i2c vc4 brcmfmac snd_soc_hdmi_codec drm_display_helper binfmt_misc brcmutil cfg80211 bcm2835_isp(C) cec bcm2835_v4l2(C) bcm2835_codec(C) rpi_hevc_dec v3d hci_uart bcm2835_unicam_legacy bcm2835_mmal_vchiq(C) videobuf2_vmalloc drm_dma_helper btbcm snd_soc_core bluetooth v4l2_mem2mem vc_sm_cma(C) v4l2_dv_timings gpu_sched v4l2_fwnode videobuf2_dma_contig v4l2_async videobuf2_memops drm_shmem_helper videobuf2_v4l2 ecdh_generic ecc videodev snd_compress drm_kms_helper rfkill libaes snd_pcm_dmaengine snd_bcm2835(C) snd_pcm raspberrypi_hwmon videobuf2_common i2c_mux_pinctrl snd_timer i2c_bcm2835 i2c_mux i2c_brcmstb snd mc raspberrypi_gpiomem nvmem_rmem drm fuse drm_panel_orientation_quirks backlight dm_mod ip_tables x_tables ipv6 uio_pdrv_genirq uio
[24971.284415] CPU: 1 UID: 0 PID: 361 Comm: SMIO Tainted: G C 6.12.25+rpt-rpi-v8 #1 Debian 1:6.12.25-1+rpt1
[24971.284430] Tainted: [C]=CRAP
[24971.284435] Hardware name: Raspberry Pi 4 Model B Rev 1.5 (DT)
[24971.284443] pstate: 20000005 (nzCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[24971.284452] pc : vc_sm_release_resource+0x54/0xf8 [vc_sm_cma]
[24971.284478] lr : vc_sm_release_resource+0x50/0xf8 [vc_sm_cma]
[24971.284490] sp : ffffffc081313cd0
[24971.284495] x29: ffffffc081313cd0 x28: ffffffc0818d8a10 x27: ffffffc0818d8a18
[24971.284509] x26: ffffff8082696088 x25: ffffff8082696068 x24: dead000000000100
[24971.284522] x23: dead000000000122 x22: ffffff80810bf1a0 x21: ffffffe82843a000
[24971.284534] x20: ffffffe82843a000 x19: ffffff80810bf180 x18: 0000000000000002
[24971.284547] x17: ca8de9bfe6e30a08 x16: ffffffe84638b2e0 x15: ffffffc081313aa0
[24971.284560] x14: 0000000000000004 x13: ffffff8040eeb0e8 x12: 0000000000000000
[24971.284578] x11: ffffff8042780110 x10: ffffff8042780000 x9 : ffffffe828435288
[24971.284594] x8 : ffffff8042780028 x7 : 0000000000000034 x6 : 000000000000000c
[24971.284610] x5 : 0000000000000000 x4 : 0000000000000000 x3 : 0000000000000000
[24971.284626] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffffff8040eeb100
[24971.284644] Call trace:
[24971.284652] vc_sm_release_resource+0x54/0xf8 [vc_sm_cma]
[24971.284665] vc_sm_vpu_event+0x41c/0x510 [vc_sm_cma]
[24971.284676] vc_sm_cma_vchi_videocore_io+0x1e4/0x3a0 [vc_sm_cma]
[24971.284686] kthread+0x11c/0x128
[24971.284704] ret_from_fork+0x10/0x20
[24971.284726] Code: f9438280 91020000 94000c5f a9400662 (f9000441)
[24971.284742] ---[ end trace 0000000000000000 ]---
…even tough the service recovered by restarting, it did not very gracefully and remained dysfunctional unfortunately:
Jun 22 22:06:45 cyberscope openflexure-microscope-server[601]: INFO: Waiting for connections to close. (CTRL+C to force quit)
[repeated ~60 times]
Jun 22 22:08:15 cyberscope systemd[1]: openflexure-microscope-server.service: State 'stop-sigterm' timed out. Killing.
Jun 22 22:08:15 cyberscope systemd[1]: openflexure-microscope-server.service: Killing process 601 (openflexure-mic) with signal SIGKILL.
Jun 22 22:08:15 cyberscope systemd[1]: openflexure-microscope-server.service: Killing process 773 (openflexure-ust) with signal SIGKILL.
Jun 22 22:08:15 cyberscope systemd[1]: openflexure-microscope-server.service: Killing process 782 (n/a) with signal SIGKILL.
Jun 22 22:08:15 cyberscope systemd[1]: openflexure-microscope-server.service: Killing process 786 (openflexure-mic) with signal SIGKILL.
Jun 22 22:08:15 cyberscope kernel: vc_sm_cma_import_dmabuf: imported vc_sm_cma_get_buffer failed -512
Jun 22 22:08:15 cyberscope kernel: bcm2835_mmal_vchiq: vchiq_mmal_submit_buffer: vc_sm_import_dmabuf_fd failed, ret -512
Jun 22 22:08:15 cyberscope kernel: bcm2835-codec bcm2835-codec: device_run: Failed submitting ip buffer
Jun 22 22:08:15 cyberscope systemd[1]: openflexure-microscope-server.service: Killing process 787 (openflexure-mic) with signal SIGKILL.
Jun 22 22:08:15 cyberscope systemd[1]: openflexure-microscope-server.service: Killing process 789 (openflexure-mic) with signal SIGKILL.
Jun 22 22:08:15 cyberscope systemd[1]: openflexure-microscope-server.service: Killing process 790 (n/a) with signal SIGKILL.
Jun 22 22:08:15 cyberscope kernel: ------------[ cut here ]------------
Jun 22 22:08:15 cyberscope kernel: WARNING: CPU: 3 PID: 787 at drivers/media/common/videobuf2/videobuf2-core.c:2215 __vb2_queue_cancel+0x238/0x2d8 [videobuf2_common]
Jun 22 22:08:15 cyberscope kernel: Modules linked in: cmac algif_hash aes_arm64 aes_generic algif_skcipher af_alg bnep brcmfmac_wcc imx219 v4l2_cci regmap_i2c vc4 brcmfmac snd_soc_hdmi_codec drm_display_helper binfmt_misc brcmutil cfg80211 bcm283>
Jun 22 22:08:15 cyberscope kernel: CPU: 3 UID: 105 PID: 787 Comm: openflexure-mic Tainted: G D C 6.12.25+rpt-rpi-v8 #1 Debian 1:6.12.25-1+rpt1
Jun 22 22:08:15 cyberscope kernel: Tainted: [D]=DIE, [C]=CRAP
Jun 22 22:08:15 cyberscope kernel: Hardware name: Raspberry Pi 4 Model B Rev 1.5 (DT)
Jun 22 22:08:15 cyberscope kernel: pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
Jun 22 22:08:15 cyberscope kernel: pc : __vb2_queue_cancel+0x238/0x2d8 [videobuf2_common]
Jun 22 22:08:15 cyberscope kernel: lr : __vb2_queue_cancel+0x34/0x2d8 [videobuf2_common]
Jun 22 22:08:15 cyberscope kernel: sp : ffffffc082a23a30
Jun 22 22:08:15 cyberscope kernel: x29: ffffffc082a23a30 x28: ffffff804580a100 x27: 0000000000000009
Jun 22 22:08:15 cyberscope kernel: x26: 0000000000000001 x25: 0000000000000000 x24: ffffff804580a700
Jun 22 22:08:15 cyberscope kernel: x23: ffffff804056cf20 x22: ffffff80439e0da8 x21: ffffff8043acad48
Jun 22 22:08:15 cyberscope kernel: x20: ffffff80439e0e50 x19: ffffff80439e0da8 x18: 0000000000000002
Jun 22 22:08:15 cyberscope kernel: x17: 0000000100000000 x16: ffffffe84595c8f0 x15: ffffffc081923b80
Jun 22 22:08:15 cyberscope kernel: x14: 0000000000000004 x13: ffffff8044e40028 x12: 0000000000000000
Jun 22 22:08:15 cyberscope kernel: x11: ffffff808e80ee60 x10: ffffff808e80eda0 x9 : ffffffe84595cab8
Jun 22 22:08:15 cyberscope kernel: x8 : ffffffc082a23940 x7 : 0000000000000000 x6 : ffffff8042780470
Jun 22 22:08:15 cyberscope kernel: x5 : 0000000000150010 x4 : fffffffec205f6a0 x3 : 0000000000150010
Jun 22 22:08:15 cyberscope kernel: x2 : 0000000000000000 x1 : 0000000000000000 x0 : 0000000000000001
Jun 22 22:08:15 cyberscope kernel: Call trace:
Jun 22 22:08:15 cyberscope kernel: __vb2_queue_cancel+0x238/0x2d8 [videobuf2_common]
Jun 22 22:08:15 cyberscope kernel: vb2_core_queue_release+0x2c/0x88 [videobuf2_common]
Jun 22 22:08:15 cyberscope kernel: vb2_queue_release+0x18/0x30 [videobuf2_v4l2]
Jun 22 22:08:15 cyberscope kernel: v4l2_m2m_ctx_release+0x30/0x50 [v4l2_mem2mem]
Jun 22 22:08:15 cyberscope kernel: bcm2835_codec_release+0x64/0x110 [bcm2835_codec]
Jun 22 22:08:15 cyberscope kernel: v4l2_release+0xec/0x100 [videodev]
Jun 22 22:08:15 cyberscope kernel: __fput+0xd0/0x2e0
Jun 22 22:08:15 cyberscope kernel: ____fput+0x1c/0x30
Jun 22 22:08:15 cyberscope kernel: task_work_run+0x80/0xe8
Jun 22 22:08:15 cyberscope kernel: do_exit+0x2e8/0x9c0
Jun 22 22:08:15 cyberscope kernel: do_group_exit+0x3c/0xa0
Jun 22 22:08:15 cyberscope kernel: get_signal+0x9ac/0x9c8
Jun 22 22:08:15 cyberscope kernel: do_signal+0xf8/0x1120
Jun 22 22:08:15 cyberscope kernel: do_notify_resume+0xd0/0x150
Jun 22 22:08:15 cyberscope kernel: el0_svc_compat+0x6c/0x80
Jun 22 22:08:15 cyberscope kernel: el0t_32_sync_handler+0x98/0x140
Jun 22 22:08:15 cyberscope kernel: el0t_32_sync+0x194/0x198
Jun 22 22:08:15 cyberscope kernel: ---[ end trace 0000000000000000 ]---
Jun 22 22:08:15 cyberscope kernel: videobuf2_common: driver bug: stop_streaming operation is leaving buffer 5 in active state
Jun 22 22:08:15 cyberscope systemd[1]: openflexure-microscope-server.service: Main process exited, code=killed, status=9/KILL
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ An ExecStart= process belonging to unit openflexure-microscope-server.service has exited.
░░ The process' exit code is 'killed' and its exit status is 9.
Jun 22 22:08:15 cyberscope systemd[1]: openflexure-microscope-server.service: Failed with result 'timeout'.
░░ Subject: Unit failed
░░ The unit openflexure-microscope-server.service has entered the 'failed' state with result 'timeout'.
Jun 22 22:08:15 cyberscope systemd[1]: Stopped openflexure-microscope-server.service - Run the OpenFlexure Microscope software using LabThings.
░░ Subject: A stop job for unit openflexure-microscope-server.service has finished
…not sure, what could have caused this, because there was not very much more helpful information in the log, but i tought you might wanna know… (next time i’ll do gitlab-issues, i promise
P.S.: I ended up restarting the pi (gracefully) and what went well is that the microscope remembered it’s position, even tough the scanning crashed, so no recalibration of X/Y/Z origins were needed, which is good!
