I’m currently using v3 version of server and have both upright and low cost versions of Openflexure microscope.
In upright version after calibrating both camera and stage “click to move” function works as intended but, when using slide scan function i noticed stage make very small moves and resultant stitched images are overlapped images of very close areas.
Here is example of stitched image:
Calibration details of current microscope:
- Current CSM Matrix: [ [ -4.387, 0.044 ], [ -0.108, -4.161 ] ]
- Pixels per motor step: 0.076
- Full field of view: [ 62, 47 ] motor steps
Here is calibration details of other low cost microscope:
- Current CSM Matrix: [ [ 0.011, 4.562 ], [ -4.971, 0.047 ] ]
- Pixels per motor step: 4.767
- Full field of view: [ 3909, 2936 ] motor steps
I also have a high resulotion with upright configuration that has similar problem which is why i think it is related to upright configuration.
Thanks in advance.
Edit: Edited lost microscope to low cost microscope.
