Hi everyone,
We have just released v3.0.0-beta1. We soon be going around the website and making a few updates, but we want our community here to know about it first.
Beta1 is a major milestone in the software overhaul, we now believe it is good enough for most of our users with a few caveats for specific use cases that we will work on before final release.
Release notes (since Alpha 5)
With this release, we move v3 from alpha to beta 1. This release has combined some essential back-end changes with improving the user experience, especially during calibration and scanning. It also sees the return of the Gallery and Full SD card images with a graphical interface directly from the Pi!
Some highlights of the release:
- A new Gallery tab replaces the Scan List tab With significant improvements including a faster database driven back end, new views and filtering, and improvements to the viewer.
- Building a “full” SD card image with a graphical OS
- Huge improvements to scanning including increase seed, previews starting earlier, a view for settings mid-scan, and improvements to the stitching algorithm
- A new camera API which makes it easier to add new cameras, and better defines the capturing and streaming modes for cameras
- Continued improvement and modernisation of the webapp including library modernisation, improved logging tab, and a better mobile/touchscreen experience.
- Global locking of the server to stop actions happening at the same time.
- Fixed autofocus frame timing so autofocus no longer overshoots.
- A new microscope management server on port 5001
- OS migration from Debian Bookworm to Debian Trixie
Installation
To burn the OS you will need version 2 of the Raspberry Pi imager software. Version 1.9.X doesn’t customise the OS correctly.
- Open Imager2
- Select App options
- Click the edit button next to “Content Repository”
- Select “Use custom URL” and paste in the following URL: https://build.openflexure.org/raspbian-openflexure/v3_pre_release/2026-08-26-raspios-openflexure-trixie-arm64/manifest.json
- Select Apply & Restart
- Now you can select:
Raspberry Pi 4OpenFlexure- If you want a full OS including a desktop:
OpenFlexure Raspbian v3.0.0-beta1 Full, OR - If you want a lite image for remote control only:
OpenFlexure Raspbian v3.0.0-beta1 Lite
- Select your SD card from the list
- give your microscope a name, and select Next
- Leave the localisation settings as they are and click Next
- Choose a user name and password then click Next
- Optionally enter your Wifi details, but you can skip this (you may need to delete the SSID for it to let you click Next)
- Turn Enable SSH on and click Use Password Authentication (Unless you understand SSH keys and how to manage them)
- Finally click write and wait for it to finish
Should I switch to v3.0.0-beta-1
Probably! You perhaps try it on a new SD card rather than wipe your current working OS.
- If you are using a v3.0.0-alpha - Certainly, yes
- If you use v2 of the server (the release currently on the website) - Probably, unless
- You use the nano/pico workaround for the motor board - We need to update the firmware for these, we are working on it. (With an older Sangaboard, you may be required to update the firmware)
- You use a delta stage - There is currently no Delta Stage support, we are looking to add it soon
- You need a specific extension - We have plans for a better extension experience, but currently it is not ready. Due to the almost total re-write of the software v2 extensions do not work
When will v3.0.0 be released
There are a number of things remaining before a full release including:
- More users and user feedback is needed (installing beta1 and giving us feedback will help us a lot)
- A strategy/mechanism for OS/Server upgrades (Help wanted!!)
- A new extension framework
- Delta stage and other motorboard support
- A configuration interface for changing plugins and camera/moorboard/stage configuration
