I posted here before about the optical tweezers we built on OpenFlexure. For that setup, we wanted to develop an extension to control the experiment, calibrate the trap and do a bit of microrheology.
These measurements need a lot of data points, so we developed a way to record faster using cropped sensor modes on the Raspberry Pi Camera Module 2. We’ve put this into Fast Trap Tracker, which brings recording, bead tracking and analysis into the OpenFlexure interface. It currently works with OpenFlexure v2.9.
We’d like to contribute it so others can try it too. What’s the best way to do that? Should we prepare a merge request to microscope-extensions, or is there another route you’d recommend? I am not very familiar with the process.
The last OpenFlexure Server v2 was v2.11. This is probably not significantly different from v2.9, although some if the later changes were in the camera (mainly colour correction). The extensions repository is still for server v2 extensions, so a merge request to there would make your work visible.
The main project is moving to a new version of the server to work with a more up-to-date operating system, latest Python etc. It is a major breaking change from v2, and does not yet have a stable framework for extensions.
Thanks, William, for the quick reply. I’d like to keep the code in my current repository and share it with microscope-extensions so it appears under Shared projects. I tried “Invite a group”, but OpenFlexure doesn’t appear in the list. My GitLab username is ali.azadbakht. Do you know what is the best solution?
