Compact Field Dissection Microscope
I have been looking at the OFM Field Dissection Microscope for a while and always had the feeling that it just doesn’t quite deserve the title as it is too big and bulky to be taken off the desk. So in the back of my mind I have been wondering how it actually should look like. So just now are some loose thought I had on that topic coming together:
  • The arm with the optics need to stick out toward the user to give good access to the speciment
  • The microscope should rather lean back than enclosing the speciment
  • Have the center of gravity as low as possible while still having the screen (mostly) above the optics
  • Store the screen well protected and just assemble or fold out the screen when in use
  • Store the optics arm save during transportation
  • Have fold out / detachable legs for a stable footprint
So I have been asking myself how compact can the microscope be when being transported. Obviously we need at least the area of the screen and the thickness of the screen and the height of the Raspberry Pi in the other direction. As my creativity is very limited I start with a box of these dimmensions: ~17x13x5 cm The focussing mechanism would then fit to the narrow sides - either the short or the longer one. This depends a bit on the working distance of the optics for which I have not yet found the numbers for. The short side would make folding up the screen a lot easier, though. So that’s what I am going with for now. The unfolded microscope could then look roughly like this:
Is this something people think is worth having? Or am I misunderstanding the use case of the Field Dissection Microscope?
